| Single Stage cooling Single stage vapor phase -50c |
Thread Tools | Display Modes |
#1 |
![]() Join Date: Aug 2009
Build log Some time ago i found a really cheap, shitty looking mach 2 gt. The "owner" told me he never had used it but got it when a friend of his moved. So i bought it thinking it would be leaking without any gas in it. When i got home i got a pleasant suprise The unit worked very well, might have been a little short on gas, but it pulled down to -44 and held a celeron 430 at -40. Well since i dont own a 775 mobo or cpu and the only mounting kit included was the 775, i havent done any more testing on it really. The unit itself was in very bad shape. The front was missing, the front led panel was also gone so was the evapprobe. The side doors were hanging and it looked really crappy when i picked it up. Below is a pic of the unit itself standing on my floor. My plan with this unit is to keep the compressor (NL11F) and replace everything else. I want this unit to be able to handle about 250w load at as low temperature as possible around -35 is my goal. I will also try and get a new case built. "Rebuilt" electronics with a simple on/off switch instead of the annoying molex connector the mach 2 has. When i was looking for evap/condensor i asked some people at various forums for pricing and avalibilty and finally decided to buy from Piotres here at the forum. After alot of pming back and forth i bought evap with suction line and a condensor from him Yesterday i got the package ( about 10days from poland->sweden and the swedish mail service had it for 4days of those 10days ), it was like christmas eve when i opened the package I let the pics do the speaking ![]() ![]() A big black package :O ![]() Evap with suction line, schrader valves, filter and condensor with fan ![]() Thank my camera for the blurry pic... To do list
Questions As in every build i also have some questions. This will be my first real build but not my first SS. First of all, im thinking of a suction acumulator.. Will i need one for this build? A pure estethical issue now. Would you prefer one or two switches, one for fan and comp or one for each? Also ive read some about the dry filter placement. I think of placing it with the side from the condensor down and the side to the cap tubing "up". I will not place it vertical but more in like a 45degree angle if you understand what im trying to describe ![]() I also bought a 320w tec to use as a loaddummy at first, but now ive read that tecs suck as loaddummys so here im open for suggestions. I can get hold of a cartridge heater for a reasonable ammount of money but i cant get a copper or alu piece for anywhere near reasonable money ![]() So do you have any do and dont you want to share with me? When this buildlogg has been updated i will update the topic with *Update 23/9-09* and the update with be in a post or on the bottom of this post, havent decided yet If you have any comments on how i should arrange this so its easy to follow please write them here or throw me a pm
#2 |
![]() ![]() ![]() Join Date: Aug 2008
I cant help you mate but sure someone will, We love everything sub zero on here. So good luck and loads of pics would be nice. X
#3 |
#4 |
![]() ![]() ![]() Join Date: Nov 2007
Nice little project Snowman, looking forward to seeing your ideas for a case
#5 | |
Quote:
I was hoping to present the first prototype case today but it been to long since ive actually worked with inventor so it doesnt want to cooperate. Thought that you could use what you write as lines and the do other commands on it but apparently you couldnt..
#6 |
Bench team Hwbot- Hardware junkie
![]() Join Date: May 2009
Good luck with this, I'm looking forward to some results.
#7 |
Bench team-Hwbot-hardware Master
![]() ![]() ![]() ![]() Join Date: Nov 2007
Good luck look forward to seeing this move ahead
#8 |
Thx guys
Got some new batteries for my camera today so heres some more pics.![]() Pic of the condensor, the 3870x2 joins the pic for refrence ![]() ![]() ![]() If you could choose would you have 1 or 2 on/off switches on the front of the case? ? Last edited by snowman89; 23-09-2009 at 04:50 PM. |
#9 | ||
<( ^_^ )>
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008
Woah thats one nice condensor where did you get that from and all the best with this man
__________________
Quote:
Quote:
#10 |
#11 |
This weekend i finally got all the parts i needed. I got it all solderd together and finished it all. But im totally sick of this unit...
First i had it on while tuning it. Then it held -30/31 with 250w load. Now, 4hours later it pulls down to -54 without load and cant hold 250w for shit... It goes to + degrees then i just shut it off... Searched for leaks now but there arent any, also checked for leaks with nitrogen first before vaccum. When it held -30/31 i had 15bar high side and 0.5bar low side. It was filled with about 200g of r404 What can really be the problem? |
#12 | |
Bench team-Hwbot Guru-hardware master
Quote:
it seams to much flux got in to the filter and the past in to the cap tube
__________________
#13 | |
Quote:
From -40 it drops with about 0.2C/s edit: Im speechless, now it sits at -53.5 and at first there was ice to half the suction acumulator and then it all just defrosted :S Whats really going on? And when i start the dummyload about 90% of the suction line and suction acumulator gets frosted ![]() When it gets to about -25C the line starts to defrost again.. :S Now i shutted the load dummy off at -13C and after about 30S its back at -39C Last edited by snowman89; 15-11-2009 at 09:22 PM. |
#14 |
Phase Guru
![]() ![]() Join Date: May 2008
IMO it's humidity inside it . What stuff You've used to make vaccum inside unit ?
__________________
Phase-change units, cascades, chillers and Ln2/DI containers builder - contact : piotres@boo.pl
or PM contact sorry no MSN or ICQ ![]() |
#15 | |
Quote:
![]() How do i fix this the easiest way? Dont really want to change oil and dry filter ![]() Are you 100% sure? Why does it behave like this if its moisture inside? Here's some pics of it. Havent done any insulation yet and i wont do it untill its working 100% ![]() ![]() ![]() ![]()
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
