BenchTec
Go Back   BenchTec > Forum information > BenchTec Reviews
BenchTec Reviews 56K unwise! All BT-UK reviews in here
Reply
Thread Tools Display Modes
Old 16-11-2009, 08:51 PM   #1
sacha35
Super Moderator-Benchtec Legend
sacha35's Avatar
sacha35 is on a distinguished road
Default ASUS SABERTOOTH P55i Motherboard Review
Introduction
THE ASUS SABERTOOTH P55i Motherboard
As always ASUS is at the forefront of motherboard innovation and technology, their track record of late certainly speaks for itself still being The No1 Motherboard Manufacturer in the World it is no surprise that they have Brought to use the ASUS sabertoothP55i Motherboard.
Specifications
CPU
Intel® Socket 1156 Core™ i7 Processor/Core™ i5 Processor Supports Intel® Turbo Boost Technology
Chipset:
Intel® P55 Express Chipset
Memory:
4 x DIMM, Max. 16 GB, DDR3 2000/1800/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Refer to Memory QVL (Qualified Vendors List) for details.
Please visit www.asus.com or refer to the user manual for the Memory QVL.
Expansion Slots
2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
3 x PCIe 2.0 x1 (2.5GT/s)
2 x PCI
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports ATI® Quad-GPU CrossFireX™ Technology
Storage:
Intel® P55 Express Chipset built-in
6 xSATA 3.0 Gb/s ports (black)
Intel Matrix Storage Technology Support RAID 0,1,5,10
JMicron® JMB363 PATA and SATA controller
1 xUltraDMA 133/100/66 for up to 2 PATA devices
1 xExternal SATA (SATA On-the-Go)
JMicron® JMB322 (DriveXpert Technology)
2 x SATA 3.0 Gb/s ports (orange and white )
Supports EZ Backup and SuperSpeed functions
Drive Xpert function is available only when the hard disk drives are set as data drives
LAN
Realtek® 8112L PCIe Gigabit LAN controller featuring AI NET2
Audio
VIA® VT2020 10-Channel High Definition Audio CODEC
Absolute Pitch BD192/24 featuring ENVY HD
DTS Surround Sensation UltraPC
Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
Optical S/PDIF out port at back I/O
ASUS Noise Filter
IEEE 1394
VIA® 6308P controller supports 2 x 1394a ports (one at mid-board; one at back panel)
USB
14 USB 2.0/1.1 ports (6 ports at mid-board, 8 ports at back panel)
ASUS Unique Features
Exclusive TUF Features
TUF ENGINE!" Power Design
12-phase CPU Power
2-phase Memory Power
2-phase VTT_CPU Power
E.S.P. : Efficient Switching Power Design for 3VSB/1.8V/1.05V
TUF Cap. & MOSFET (certified by military-standard)
Ultimate COOL!" Thermal Solution
CeraM!X Heatsink Coating Tech.
CoolMem!
T.Probe Technology
ASUS Fan Xpert
Safe & Stable!-Guardian Angel
MemOK!
Drive Xpert
ESD Guards
EMI Eliminator
Special Features
ASUS Q-Connector
ASUS Q-Shield
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
ASUS CrashFree BIOS 3
ASUS EZ Flash 2
ASUS MyLogo 2
ASUS O.C. Profile
Multi-language BIOS
Back Panel I/O Ports
1 x PS/2 Keyboard (Purple)
1 x PS/2 mouse port (Green)
1 x Optical S/PDIF Output
1 x IEEE1394a
1 x LAN (RJ45) port
1 x External SATA port
8 x USB 2.0/1.1
10-channel Audio I/O
Internal I/O Connectors
3 x USB connectors support additional 6 USB ports
1 x IDE connector
6 x SATA connectors
1 x IEEE 1394a connector
1 x CPU Fan connector
1 x Power Fan connector
2 x Drive Xpert SATA connectors (orange and white)
2 x Chassis Fan connector (1x4-pin, 1x3-pin)
1 x Mem Fan connector
1 x COM port
Front panel audio connector
1 x S/PDIF Out Header
CD audio in
24-pin ATX Power connector
1 x 8-pin ATX 12V Power connector
System Panel(Q-Connector)
1 x MemOK! button
1 x Power on switch
1 x Reset switch
BIOS
16 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a,
Manageability
WfM 2.0,DMI 2.0,WOL by PME,WOR by PME,PXE
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Front, rear cover and inside of the packaging that houses the ASUS Sabertooth P55i Motherboard.
Accessories .
6 x SATA 3.0 GB/s cables
1 x Ultra DMA 133/100/66 cable
1 x 2-port USB 2.0 and 1 port eSATA module
Driver/support DVD
1x ASUS SLI bridge connector
1x 2-in-1 ASUS Q-Connector kit
1x ASUS Q-Shield
1x CoolMem frame, fan not included
User Guide
__________________
sacha35 is offline   Reply With Quote
Old 16-11-2009, 08:51 PM   #2
sacha35
sacha35's Avatar
The ASUS SABERTOOTH P55 Motherboard.
In the review I will be taking a close look at all the facts and features that the ASUS SABERTOOTH 55i Motherboard has to offer over the rest of the ASUS range of P55 of motherboards, so Let's take a Look around this board and see what it has to offer.
The newly-developed "TUF" (The Ultimate Force) Series socket LGA1156 for Intel® Core™ i7/Core™ i5 Processors, Intel® P55 Express chipset supports Intel® Turbo Boost Technology and equipped with the new Ceramic heatsink's which delivers exceptional cooling to active components and outstanding system stability even under the most intense operating conditions, designed around the "Marine Cool" concept, the TUF Series triumphs to deliver top notch performance at all times.
The SABERTOOTH 55i motherboard delivers E.S.P. (Efficient Switching Power) to all major components for system efficiency.
Besides delivering efficient power to the CPU and memory, the power design also applies the same level of efficient power to the PCIex16 expansion slots and IC, This intern improves overall power efficiency and reduces the amount of heat generated resulting in cooler and a more reliable operation.
Unique CeraM!X Microfin Coating
The ceramics replace traditional anti-oxidant compounds to create a microfin surface texture for enhanced cooling, This rough surface offers an expanded area for heat induction into the surrounding air and as a result, more heat is rapidly conducted away from the active system—allowing users to enjoy previously unattainable levels of stability, all its capacitors and VRM MOSFETs have been certified for military-level use through stringent testing.
The ASUS SABERTOOTH 55i motherboard, equipped with the new CeraM!X heatsink, delivers exceptional cooling to active components and
The heasink over the PCH on the bottom side of the board
There is also a very good layout around the socket area.
ASUS have included four DIMM Slots which can accommodate up to 4 x DIMM, max. 16GB, DDR3 2000/1800/1600/1333/1066MHz, non-ECC, unbuffered memory Dual channel memory architecture
Supporting Intel® Extreme Memory Profile (XMP)
The memory retention method is a bit different from what has been used over the past, on one end the locking mechanism pushes straight down rather than rotating into place.
MemOK button.
ASUS has come up with MemOK button, ASUS refers to MemOK as a “memory rescue tool”. Simply push the MemOK button on the motherboard and the technology automatically determines the failsafe memory settings needed to boot the motherboard.
The P55 Express chipset natively support six SATA ports which this board has four black in the sideways facing orientation and two at the bottom of the board, This prevents any large video card from interfering with the SATA ports .
There are also 2 x SATA 3.0 Gb/s JMicron® JMB322 (DriveXpert Technology) ports (orange and white ) which Supports EZ Backup and SuperSpeed functions
There are two full-length PCIEX x16 slots that supports both ATI Quad-GPU CrossfireX and nVidia Quad-GPU SLI PCI Express 2.0 x16 support single at x16 or dual at x8 mode, the board also has three PCI Express x1 slots and two legacy PCI slots.
Nice easy access to the power and reset buttons at the bottom of the motherboard.
__________________
Old 16-11-2009, 08:52 PM   #3
sacha35
sacha35's Avatar
Onboard sound on the motherboard is provided
VIA® VT2020 10-Channel High Definition Audio CODEC ,Absolute Pitch BD192/24 featuring ENVY HD
DTS Surround Sensation UltraPC ,Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking , Optical S/PDIF out port at back I/O, ASUS Noise Filter.
The rear Panel I/O Ports
1 x PS/2 Keyboard (Purple), 1 x PS/2 mouse port (Green), 1 x Optical S/PDIF Output, 1 x IEEE1394a, 1 x LAN (RJ45) port, 1 x External SATA port, 8 x USB 2.0/1.1, 10-channel Audio I/O.
The Bios
Click on the link to see the slide show.
Test System
Intel Core i7 LGA-1156 870 CPU Stock Watercooled cooled.
4GB Corsair CMGS2GX3M1A2200C8 ES1 Cas 8 memory running at 2200MHz
Single XFX GTX 295
ASUS 4870 X 2 in crossfire
Samsung HD322HJ
Zalman Reserator XT
Acard
Corsair HX1000
Windows 7 32-bit stock install with no tweaks.
Before running any tests I needed to find out what the system and the Intel i7 870 is capable of giving me in regards of clocks and memory speeds as only a standard water-cooling unit is being used to cool the CPU.
Maximum CPU stable super pi 1m 4815.7MHz
Now to see what sort of speeds I could get from the Air cooled memory.
2395.4MHz Cas 8, very good for the air cooled sticks as this motherboard is only supposed support a Maximum of 2000MHz
http://valid.canardpc.com/show_oc.php?id=830932
Now for the Tests
• Wprime 1024m and 32m
• PiFast
• Supper PI 32M
• Cinebench
• PCmark 05
• Everest catch and memory
• 3Dmark 03
• 3Dmark 05
• 3Dmark 06
• 3Dmark Vantage
__________________
Old 16-11-2009, 08:52 PM   #4
sacha35
sacha35's Avatar
Wprime 32m and 1024m
PiFast
Supper PI 32M
Cinebench
PCmark 05
Everest cache and memory
3Dmark 03 Single XFX 295
3Dmark 03 ASUS 4870 x 2 crossfire
3Dmark 05 Single XFX 295
3Dmark 05 ASUS 4870 x 2 crossfire
3Dmark 06 Single XFX 295
3Dmark 06 ASUS 4870 x 2 crossfire
3Dmark Vantage Single XFX 295
3Dmark Vantage ASUS 4870 x 2 crossfire
Conclusion
What you have with the ASUS SABERTOOTH P55i Motherboard is just what is says on the box, it has a good range of features and accessories as you'd expect from any of the Asus Motherboard's on the market today, But where the SABERTOOTH P55i Motherboard excels is in the power delivery with the components used, no matter how hard I tried this motherboard just would not fail, pushing it to the limits and beyond with only a cheap water-cooling system being used the board would always post unlike some of the motherboards I have tested that can be a bit awkward at times to say the least.
This motherboard has a superb layout and all the connectors on the board are just where you'd expect to find them, the features and technology coupled with the new VIA VT2020 10-channel audio chipset delivers some of the most realistic and accurate audio from a PC.
The performance is there just like the recently reviewed ASUS Maximus III and the Asus P7P55D Deluxe I did , it may not have the bling factor or all the extras the other boards have to offer, but when it comes to performance it is truly impressive and is right up there with the best.
To be honest I thought this motherboard was just going to be a marketing gimmick with the Ceramic heatsink's and resilient components that pass demanding military-style testing but once again Asus have proved me totally wrong.
Overall, for the serious overclocker going the P55 route the ASUS Maximus III is still the board to beat, but the ASUS SABERTOOTH P55i Motherboard is no slouch ether as the results in all the tests that I did with this motherboard speak for themselves and most of all it did not falter once.
The motherboard coupled with some newer GFX cards and some better cooling and world records could fall very easily and quickly in the P55 range with this board and for that reason alone I highly recommend this item.
__________________
Old 16-11-2009, 09:03 PM   #5
Dualist
Man called Unkle
Dualist's Avatar
Dualist is on a distinguished road
Really nice review Paul
Love the memory, does it come in flavours of three.?
But is the 200 bclk limit the board, or your chip.? But not happy about the two pci-e lanes split down into two x8 when both used
__________________
Sry for my bad English
(I might be pissed)
נְפִילִים
Dualist is offline   Reply With Quote
Old 16-11-2009, 09:20 PM   #6
sacha35
sacha35's Avatar
Na mate had the board upto 229Bclock so there is more in it when it gets cold, and yes the memory comes in three
__________________
Old 16-11-2009, 09:55 PM   #7
scooter.jay
Bench team-Hwbot-hardware Master
scooter.jay's Avatar
scooter.jay is on a distinguished road
Good review and a great looking board
__________________
Quote:
Originally Posted by Barron_Greenback View Post
I feel proud to be part of such a dedicated bunch of loonies
scooter.jay is offline   Reply With Quote
Old 16-11-2009, 09:57 PM   #8
Bustah
Bench team-Hwbot Guru-Hardware Master
Bustah's Avatar
Bustah is on a distinguished road
nice looking board indeed....That ram looks sweet too!
Bustah is offline   Reply With Quote
Old 16-11-2009, 10:07 PM   #9
jabski
jabski's Avatar
jabski is on a distinguished road
looks good Paul. Thanks for the info
__________________
I7 975 XE
HWBOT team captain : Any problems with hwbot then pm me or catch me on msn
jabski is offline   Reply With Quote
Old 16-11-2009, 10:11 PM   #10
RawZ
Bench team member-hardware Junkie
RawZ's Avatar
RawZ is on a distinguished road
Nice board and thanks for the review mate. Great read.
__________________
AMD Phenom II X3 705e UNLOCKED @ X4 4.1Ghz
Gigabyte GA-MA790FXT-UD5P
Sapphire HD 4670 512MB Ultimate
2GB Super Talent Project X @ 1600Mhz 7-6-6-18
320GB WD AAKS Caviar Blue
Corsair VX 450W w/ Sharkoon 1000 "Golf Ball"
HK 3.0 LT | RX120 | San Ace H1011
RawZ is offline   Reply With Quote
Old 16-11-2009, 10:24 PM   #11
PeterStoba
PeterStoba's Avatar
PeterStoba is on a distinguished road
I love this board, definately a winner.
__________________
My Benching Systems
Gigabyte GA-X58-Extreme - Core i7 920 D0 - 6GB Patriot Viper 1600Mhz - XFX 5870 1GB - Custom Watercooling
Gigabyte GA-MA790XT-UD4P - Various CPUs - 2GB Kingston HyperX 1800Mhz - Various Nvidia & ATI GPUs - Custom Watercooling
Gigabyte GA-MA770-DS3 - Various CPUs - 2GB Crucial Ballistix 1066Mhz - Various Nvidia & ATI GPUs - Custom Watercooling
ASUS Rampage Extreme - Various CPUs - 4GB Kingston HyperX 1333Mhz - Various Nvidia & ATI GPUs - Custom Watercooling
PeterStoba is online now   Reply With Quote
Old 16-11-2009, 11:19 PM   #12
Greed4Speed
Phase Tech
Greed4Speed's Avatar
Greed4Speed is on a distinguished road
Nice board. Not sure about the name though, commando II would have been more appropriate judging by the looks.
Greed4Speed is offline   Reply With Quote
Old 18-11-2009, 01:21 AM   #13
El Bastardo
imprisons his guests in a commode
El Bastardo's Avatar
El Bastardo is on a distinguished road
Nice review there and some really good pics.
I have been looking at the board for some time now and i still cant make my mind up whether i like the look of it or not.Those cool metallic colours are certainly different (that Corsair ram will look great with it) but maybe it looks a bit dull.
Oh i dont know...my brain hurts.
Think the Rampage II Extreme and EVGA Classified boards look the best in my humble opinion.Kudos for Asus though for giving something else a go.
__________________
B-N...He likes to whistle in the dark.
8400 @ 4Ghz/Rampage Formula/2 GB Crucial Ballistics Tracer 8500/ThermalTake 1200Watt/TRUE/Silverstone TJ07/Creative X-Fi Fatality Pro/Logitech Z5500/XFX 8800GTX/Razor Tarantula/Logitech G9
El Bastardo is offline   Reply With Quote
Old 19-11-2009, 06:09 PM   #14
El Gappo
El Gappo's Avatar
El Gappo is on a distinguished road
how come you dont have that cool ram fan on? that's a great idea. quite a bit of interest in this over at ocn hence this thread getting so many views lol
__________________
Quote:
Originally Posted by scooter.jay View Post
Amd beware gappo + cold
El Gappo is online now   Reply With Quote
Old 19-11-2009, 06:53 PM   #15
Baz
Bench Team -Benchtec Legend
Baz's Avatar
Baz is on a distinguished road
paul so much info
your reviews are the nuts mate
__________________
Baz is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
