+ Reply to Thread
Results 1 to 12 of 12
Thread: How to get the best from your dice!
  1. #1
    Friend of the family scooter.jay's Avatar
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    Default How to get the best from your dice!
    I am starting this thread because i have now done a couple of dice sessions and i have quickly gained confidence using it for cooling. So now that i have done it a couple of times i have got the insulation thing sorted. So in this thread i would like to move on from that and find out some information about getting the most out of a dice session. Hopefully the information people post in this thread will help anyone so i will try to update it i some way and maybe make a guide out of it a later date once some testing has been done. I really want make up an easy set of rules for myself to follow as i can get a bit carried away sometimes and maybe dont get the best out of it. Basically an A-Z of tips and tricks!
  2. #2
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    Lets take this as the the first thing i'll ask questions after this and edit the post when anwsers come in to make up step by step guide.
    First question what do people recommend for scooping dice out box or putting pellets into to make it easy to add to the pot as one plastic cup i used was fine but last session i did one cup used melted a bit so must have been damaged by dice. So what is best thing to use?
    Also i have not used any temp monitoring equipment the last two times and next time i would like to could anyone give me links to some reasonable gear at a reasonable price?
    Also what temp can really be achived with dice as i have heard many different claims?
  3. #3
    Bench Team -Benchtec Legend Barron_Greenback's Avatar
    Join Date
    Nov 2007
    Location
    Tamworth
    Posts
    1,390
    Just a few things that I do before/during a session..
    - When I first install the POT, i usually fire the system up at std clocks and boot into the bios with NO ICE installed. Monitor CPU temps until they reach mid 40*c. This helps to spread out and cure the TIM before you start.
    - Good quality Acetone is a MUST. Nail polish remover does work, but contains water and affects temps quite a bit. Near as you can get to 100% pure is best. I use this stuff from Ebay
    - Dont fill the POT to the brim. This is a waste of ICE and is not required.
    - Storage of your ICE is also important if you have alot of it, 20kg+. I store mine in a large cardboard box, with 2" thick polystyrene insulation on all sides and the top. Dont keep it in plastic bags as it can set into a big lump. Always try to use the pelleted type of ICE, its nice and easy to work with.
    -Safety is also important. Always use goggles and wear gloves if your handling the stuff. Dont get cocky, it only takes one "spit in the eye" from boiling acetone at -60*c to blind you!
    -Have Fun!
    OVERCLOCKING - The process of installing high hopes, dumb luck, and several paychecks into a rectangular box which transmits a signal to a screen that displays your fate. The outcome is usually depressing.
  4. #4
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    I found as above only a small amount of dice now and then works best no point chucking loads in best piece of advice i was given.
  5. #5
    Join Date
    Jan 2008
    Location
    Nottingham, England
    Posts
    2,007
    for putting it into the pot i'd imagine a small garden trowel would perhaps be best? alan titchmarsh would be proud
    It's sad how Wile E. Coyote is remembered for his violence, and not for his brilliantly realistic paintings of tunnels.
  6. #6
    On the border weescott's Avatar
    Join Date
    Nov 2007
    Location
    Londonshire
    Posts
    616
    When I did DiCE I got 10kg blocks and had to break it up outside while in the plastic bag it came in, and take in a small amount as required.
    I'm getting a pressurised container for DiCE on tuesday. I'm not sure how easily available these are generally, but they are ideal for DiCE storage and transportation.
    Quote Originally Posted by EvOcarlos View Post
    i like to feel all the bumps and some nice control from the rear
  7. #7
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    Sounds good scott pm or post in this thread when you get this. Does having one of these mean you can slow/stop it melting away as dice benching always seems against the clock?
  8. #8
    Bench team-Hwbot Guru
    Join Date
    Dec 2007
    Location
    Leeds UK
    Posts
    310
    Insulated drinks cup (el chepo £1.50 from wilko's) works wonders as a pourer for dice. Helps keep the DICE nice and cold and usually there's enough for a good 20 mins of benching. Get a bit of condensation on the outside of the cup sometimes though so something to wipe and prevent drips is a good idea.
    Make a funnel out of a piece of paper and stick it in the top of the tube. Helps prevent stray dice/drips falling onto the mobo.
    Another quick tip is to use a rod of some sort to prevent lumps of ice/DICE forming in the bottom of the tube. Few prods now and again works wonders and can help temps significantly.
    Thermometer wise, I used a K102 unit from conrad-direct (sites down at the mo) it's dual input so allows you to monitor 2 tubes at a time if needed. Around 50 quid gets you the unit and 2 k-type probes.
    .:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
  9. #9
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    Thanks for the info Highland3r i should be able to test all of this in a couple of weeks.
  10. #10
    Bench team-Hwbot Guru-hardware Master Johnny Bravo's Avatar
    Join Date
    Nov 2007
    Location
    Edinburgh
    Posts
    912
    scooter.jay - there's a good sticky at the head of this topic should keep you well informed
  11. #11
    Join Date
    Nov 2007
    Location
    Devon
    Posts
    1,964
    Quote Originally Posted by Johnny Bravo View Post
    Yeah i know was just asking the question again as there is alot of ideas out there at the moment so as i will be having a few sessions in the near future be nice to try a few of em. Also what equipment people are using is not always the same so good to see whats being used too!
  12. #12
    Forum Member reno 456's Avatar
    Join Date
    Oct 2008
    Location
    North West of England
    Posts
    106
    I use a tablespoon with a plastic handle to put it in i find it is just the right amount and it's easy also the plastic handle stops you hand getting too cool but wood would probably be better. Always wear gloves and goggles. Freezing acetone on you hand leaves nasty freezer burns.
    Hey, I'm watching
+ Reply to Thread
Similar Threads
  1. dice
    By 8bitbreed in forum LN2 / Dry Ice
    Last Post: 29-11-2010, 12:28 PM
  2. Into DICE I go
    By Olly_K in forum LN2 / Dry Ice
    Last Post: 23-06-2009, 10:02 PM
  3. diy dice
    By EvOcarlos in forum LN2 / Dry Ice
    Last Post: 05-06-2009, 10:31 PM
  4. Just Got My DICE Pot
    By Bitemarks666 in forum LN2 / Dry Ice
    Last Post: 15-01-2009, 05:58 PM
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
