First Dice run,
Need a couple of answers from the dryice guys,
Got a pot on order will be here in couple of weeks, organizing a supply of Dry ice.
Am familiar with the board prep, same as Single stage.
A bottle of acetone 1 litre is to be obtained, any special sort?
Now the cooking begins, system will set up with xp and tested with air cooling ect.
So what comes next, start up computer with nowt in pot? Add acetone how much? Add pellets of dry ice? Or fill the container and start benching.
As the pot uses the dice do you keep it topped up or let it almost empty? Do you have to add acetone when adding more dry ice.
Just getting the prep done, will be dragging the old dfi expert for this first run, learn on old kit first, rather than putting new kit at risk.
Temp I have a fluke to measure temps, do you just take the temp down to max -71cish
