+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 40
Thread: Owl's Contraptions
  1. #16
    Sponsored by Stannah maverik-sg1's Avatar
    Join Date
    Nov 2007
    Location
    Redditch, UK
    Posts
    13,110
    Nice work there ARO
    Former HWBOT and CPC World No1 Bencher
    http://www.hwbot.org/user.do?userId=5051
    HWBOT Quote:
    (highest rank ever: 1st at 05 Nov 2006 12:30, most hwboints ever: 331.7 points at 05 Nov 2006 12:30)
    Voltage - The solution and cause of all your overclocking problems .
    Please forgive my grammar and spelling - My Keyboard is dyslexic
  2. #17
    VIP K404's Avatar
    Join Date
    Nov 2007
    Location
    Glasgow, U.K.
    Posts
    5,795
    Nice!
    Are the voltage readings from external probes, or direct from the card itself?.... if that makes sense
    Quote Originally Posted by margo baggins
    it must be proper rubbish being a cpu in the hands of any the the big boys in this team.
    Quote Originally Posted by JB
    man u sure do make for some interesting stories!....that, Kenny, is total FUBAR
    ARandomOWl: Any comments?
    Bazx: You need to get out more
    ARandomOWl: Thanks. That's the sort of comment I was looking for.
  3. #18
    Friend of the family ARandomOWL's Avatar
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    Quote Originally Posted by K404 View Post
    Nice!
    The app will retrieve data from a microcontroller via USB
    Statistically, overclocking is 719% more fun than studying, even on a bad benching day.
    Quote Originally Posted by echelon101 View Post
    Putting 1.8v through a chip is like hitting someone with a baseball bat. Do it for a short time and the chip won't be hurt...do it for a long time and it will die.
  4. #19
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    USB Communication? Check!
    Click image for larger version
    Voltage reading is quite accurate
  5. #20
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    I've got the some of the circuit assembled on a breadboard so I can bring it with me to the meet No thermocouple readings for now, need a bit more time for that. I'm also having some issues with the second PWM channel so that's missing for now too.
  6. #21
    \m/ (>.<) \m/ Dualist's Avatar
    Join Date
    Nov 2007
    Location
    In a shed in Poland
    Posts
    4,899
    Looking forward to seeing this mate, nice looking interface, great for monitoring via a lappy.
    HWBot siggy thingy no workie..!!
    Quote Originally Posted by Greed4Speed View Post
    Hope the new captains kick our asses and inspire us to get back into gear again, I volunteer to bend over first
    Quote Originally Posted by jimmyz View Post
    If stuff ain't dieing, you aren't trying.
    נְפִילִים
  7. #22
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    Quote Originally Posted by Dualist View Post
    That's the idea Nice big number so you can see at a glance.
  8. #23
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    Ok, so this has been put on hold for a while.
    One PWM channel is working. The other isn't. It seems it is an issue with the microcontroller which is non-specific to my design.
    The voltage reading are working. Although I need to work on the stability of the ADCs as the readings like to jump around a lot in practice. I think it may be to do with the wire length from the voltage source to my circuit.
    I haven't worked on the temp probes yet. Need to get a concept drawn up.
    Hopefully I will be able to work on it a bit more this summer
  9. #24
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    The unstable voltage readings seem to be caused by pickup (mains and other crap) along the length of the wire I am using between my circuit and the voltage source. I have used a software low pass filter to get rid of it and the reading is nice and clean now
    I used software instead of hardware partly because it was faster to write the smaller amount of code than it was to find the components in my draws But also, it will mean I will have less components on the final PCB (cheaper, less chance of more noise getting in, easier board design).
  10. #25
    imprisons his guests in a commode El Bastardo's Avatar
    Join Date
    Mar 2008
    Location
    Bilton/East Yorkshire
    Posts
    1,313
    Your rather good at doing gadgets like this.
    Top work fella.
    8400 @ 4Ghz/Rampage Formula/2 GB Crucial Ballistics Tracer 8500/ThermalTake 1200Watt/TRUE/Silverstone TJ07/Creative X-Fi Fatality Pro/Logitech Z5500/XFX 8800GTX/Razor Tarantula/Logitech G9
  11. #26
    Join Date
    Nov 2007
    Location
    In a shed in Poland
    Posts
    4,899
    Nice work Adrian
    But how does a software filter compare to a hardware one, I thought hardware would be better.?
    נְפִילִים
  12. #27
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    Thanks EB
    Dave, you are correct. In general, a hardware filter is better (simpler, faster and better performing depending on the hardware chosen and the software algorithm used). However for this purpose a software implementation is rather simple and therefore fast. It's not like we are filtering audio (where usually rather complicated fft algorithms are used, not easy to do on a microcontroller). But we only want to cut off frequencies below about 50Hz, and that value isn't critical.
    In simple terms, the performance (speed and quality) will be the same whether we choose a software or hardware filter.
  13. #28
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    I have done some testing and have found that putting a 10uF capacitor across the input of my ADC creates a good enough low pass filter in hardware (with the wire's resistance replacing a discrete resistor). So I think I am going to go with that for the final product and no software filtering.
    I have also decided the thermocouple interface topology which will consist of an instrumentation amplifier and a linear digital temperature sensing IC which will serve for cold-point compensation in software.
    Finally I decided that a lot of care must be taken in every stage of the PCB design to eliminate RFI interference from the PWM controller and reduce offset errors in the thermocouple amplifier to gain the maximum accuracy possible. This is project is serving both a useful purpose and a big learning experience in terms of circuit design and PCB layout.
  14. #29
    Join Date
    Nov 2009
    Location
    Manchester, UK
    Posts
    1,717
    Ok, it's coming along nicely now. Here is the complete schematic thus far Link
    Still missing thermocouple symbols (not made them yet) and a couple of other minor things.
  15. #30
    Benchtec Senior vento1's Avatar
    Join Date
    Nov 2007
    Location
    Swindoo
    Posts
    1,834
    Looks very impressive mate wish i could make sense of all of it, certainly out of my legue.
    Quote Originally Posted by Nathanial View Post
    unkie daves gonna go in dry if he see's what you done with his pot .
+ Reply to Thread
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
