Hi. I have at last got all the parts for my O/C project even a legal Windows 7 CD.
So after checking & rechecking all connections I finally plucked up cur-rage to plug it in, Bearing in mind all these parts are used & have come from all over the world.
It fired up no problem power supple LED went to green all fans spinning lots of info on screen all seamed well so I thought I would have a look into the BIOS then a Crack/Spark sound screen went blank so I powered down the computer & started to check every-thing.
Powered on again after checks went into bios again after approx 2 minutes screen went blank again the post code display seamed to indicate video card problem so checked every-thing again.
I had better mention this now my video card is a BFG 9800GTX+ Water cooled But with no water in it yet (call me a dick head if you must) but the water jacket did not get hot but the little heat sink at the end of the card did (possible needed a little fan) & the 1 Mosfet under the heat sink is possibly the problem I found the little bit of Mosfet in the bottom of the case.
I have sourced a new Mosfet & I can repair this myself no problem.
I would like to no if any of you Hi tec guys think this could be my problem, I love to tinker & if I can repair the card it would give me a great deal of satisfaction if not I will get another card. Many thanks.[IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
